Question Aorus X570 Master XMP 4000MHz Issue
tertmagert
29
Hello,
I am having issues with XMP settings sticking when I get into windows.
System:
Gigabyte Aorus X570 Master w/BIOS:F31I (latest)
Ryzen 5800x w/ EVGA CLC 280mm
G.Skill 32GB Ripjaws 4000MHz CL 16 (2 sticks in the A1/B1 config)
Nvidia RTX 3080 FE
1TB Samsung 970 evo (primary M.2 slot)
2TB Intel 660p (secondary M.2 slot)
EVGA BR1000 Watt
When I enable XMP Profile 1 it changes my BIOS to what seems like the correct speeds/timings/voltages. 4000, 16,19,19,19,39, 1.4v. When I launch windows it shows a default speed of 2133MHz with its 15CL timings. When I reboot and go into BIOS again the settings are still there but upon getting into windows again nothing has changed. I also ran into an issue when I tried to change my RAM configuration to the A2/B2 slots. Id reboot and the BIOS wouldn't recognize my primary M.2 and I could not launch into windows. I have tried manually running through some of these settings and keeping the XMP disabled but I am either missing some of the settings to change in BIOS or the motherboard simply has an issue with XMP. Is there someone that has experience with this Motherboard that could run me through the proper settings in BIOS to change or provide some other suggestions?
Thanks,
tertmagert
29
Thanks Drivingfast247. Is there any other way I can get some help here form others in the community? Not exactly sure how to use these forums well.
