Hi I have a Archer ac2300 router which has an ethernet connection on it but my master socket has Dsl line fibre from sky.
- Can I buy a cable that will go into the rj11 port to an rj45 port on router will that work ?
- Can I plug a ethernet cable into the Lan1 line of sky hub and use new router that way ?
- Should I purchase a standalone modem for it if so what should I go for ?
