System:
Q6600 OC to 3.4GHz
Vcore = 1.32V
Zalman GS1000 Case
Asus Rampage Formula Mobo
Temps before CPU lapping: Idle = 39°C Tcase; Full Load Prime95 Blend= 65°C Tcase
I was running my system using an Arctic Freezer 7 Pro CPU cooler, but last night I decided to lap my CPU as a push to anything greater than 3.4GHz is pushing my CPU over its 73°C design limit.
I've had a Thermatake Blue Orb FX sat on a shelf for several months, which was supposed to go in to the original system build, but for various reasons didn't. I figured that since I needed to remove the processor / mobo to do the lapping, I'd take the opportunity to fit the Blue ORb at the same time.
But....the temps after lapping and with the Blue Orb FX are about the same at idle (possibly a degree or two worse) and are several degrees higher under load. It is reaching 73°C Tcase within a few minutes of Prime95 running, at which point I'm stopping the test. The ambient that I was testing at was several degrees cooler than it is normally as well. Tjunc temps are at around 76°C - 81°C when Tcase is at 73°C. Under the old set-up the Tjunc tems would stabilise at around these temps.
Have I cocked something up or is the Blue Orb just not as capable as the Freezer 7 Pro? AS5 has been used with both coolers. If after the AS5 has 'settled' I get a 5°C improvement it will still mean my temps are still gonna be over what they were.
Also, does anyone know if it really matters if the Tcase goes above design spec providing the Tjunc temp don't get too hot?????
I'm pretty confident that the IHS is now properly flat as I checked it before, during and after lapping with an engineers straight edge - it is about as flat as I have ever seen
Shiny as well 😀 😀
I'd do a back to back comparison by putting the Arctic Freezer back on again, but that unfortunately means taking the mobo out again which I don't really want to do unless I have to!!
Should also say that the Blue Orb does a fantastic job of cooling the NB chipset, bring its temp down by 5°C under load! Not that it was ever in danger of overheating....
Q6600 OC to 3.4GHz
Vcore = 1.32V
Zalman GS1000 Case
