Question ARCTIC Freezer A35 A-RGB not working on ASRock AB350M Pro4
Djonito132
18
So my friend bought AB350M PRO4 motherboard with an ARCTIC Freezer A35 A-RGB but the cooler wont get detected by the BIOS at all we updated the BIOS watched tutorials googled everything to no luck so y'all are our last hope and no the cooler doesn't work most of the time spins a few times and stops
Are you sure it's fan is connected to CPU_FAN header correctly ?
In addition Light is not going to work with that MB as it doesn't have ARGB header only RGB which are not compatible with each other.
Might as well return cooler and replace with RGB one if you can.
If youhave any other fan (case fan for instance) connect it to CPU_FAN to check if header is working at all.
