Question Arctic Liquid Freezer II 360 in bequiet silent base 700 with hdd mount - will it fit?
Jun 16, 2023
Hi.
I'm wondering if Arctic Liquid Freezer II 360 will fit on the front of the Bequiet silent base 700 case with the HDD mounted in the middle of the case (above that part with the PSU). There I think it will either be a touch or not fit at all 🙁 but I'd like to make sure.
Mounting on top a bit problematic, because if I change the fans to phanteks T30 the whole thing will take up almost 7cm in height.
And I forgot to mention that I have the interior reversed, meaning the glass on the right side (looking from the front).
Not likely. See here: https://www.tomshardware.com/reviews/be-quiet-dark-base-700-case,5321-2.html (scroll down to the Cooling section)
There's an image there with a radiator and HDD cage. The 8-11mm thicker than norm Liquid Freezer probably won't clear that.
Alternative is to try taking your own measurements with a mm ruler, because you could be waiting forever on someone with the same setup as yourself.
Reactions: Iciatko
