Are 4 fans required on the h100i v2?
1323114355
Commendable
Sep 21, 2016
42
I have got the zalman z9 neo and i will buy a new cpu cooler around january. I am looking forward to getting the h100i but my chassie doesnt look like it would fit the radiator with 4 fans anywhere? I looked at few builds and people would put fans on the radiator from both sides. Maybe it is just me that is over exaggerating and it would fit in my case no problem but I dont want to waste £100 on a product that won't be compatible. However if it does fit (no idea how) then which fans should i use? static pressure or air flow?
Thank you for helping :)
I looked at your case online, and I don't see why you could not fit the dual size radiator with simply 2 fans pushing air thru it on this case.
yes single radiator users will user 2 fans to push more air through and people that overclock also use the same principal (4 fans on an H110i) to maximized the cooling of the radiator.
is it required... not really if it was, think corsair would only provide half the fans needed for their product? nope.
