[SOLVED] Are my pc parts compatible ??
Compatible? Yes but bad choices such as the poor quality PSU, expensive case & a quad core CPU when you should be able to go 6-core for a little bit more.
What country are you buying this from? I think you can do better for the budget.
I'm from ireland but buying these on amazon uk. Any ideas on what I should go for then ??
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor (£119.99 @ Amazon UK)
Motherboard: ASRock B450M-HDV R4.0 Micro ATX AM4 Motherboard (£54.53 @ Amazon UK)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory (£74.98 @ Amazon UK)
Storage: ADATA XPG SX6000 Pro 256 GB M.2-2280 NVME Solid State Drive (£53.59 @ Amazon UK)
Storage: Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive (£36.40 @ Amazon UK)
Video Card: XFX Radeon RX 570 8 GB Video Card (£132.99 @ Amazon UK)
Case: Xigmatek Frontliner ATX Mid Tower Case (£46.00 @ Amazon UK)
Power Supply: Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply (£74.98 @ Amazon UK)
Total: £593.46
Generated by PCPartPicker 2020-04-11 20:49 BST+0100
Thank you so much! Will i have any problems with this?? As in a bios update or anything like that ?
The motherboard ships with 2nd gen AMD Ryzen support so it will work with that CPU without issues. The only reason for upgrading the BIOS for the motherboard is if there is issues with getting the memory to run at 3000mhz but XMP works well so I really don't expect issues.
IMO I would consider going for that:
Type|Item|Price
CPU | AMD Ryzen 5 2600 3.4 GHz 6-Core Processor | £119.99 @ Amazon UK
Motherboard | MSI B450M-A PRO MAX Micro ATX AM4 Motherboard | £54.98 @ Amazon UK
Memory | Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3200 Memory | £74.98 @ Amazon UK
Storage | PNY CS900 120 GB 2.5" Solid State Drive | £23.92 @ Amazon UK
Storage | Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive | £36.40 @ Amazon UK
Video Card | XFX Radeon RX 570 8 GB Video Card | £132.99 @ Amazon UK
Case | GameMax Crusader ATX Mid Tower Case | £49.99 @ Amazon UK
Power Supply | GameMax RGB 550 W 80+ Gold Certified Fully Modular ATX Power Supply | £65.83 @ Amazon UK
Custom | DeepCool Fan Hub Control 4PWM Fan Speed Supports Fan with 3Pin/4Pin Cooling FH-04 | £9.99 @ Amazon UK
| Prices include shipping, taxes, rebates, and discounts |
| Total | £569.07
| Generated by PCPartPicker 2020-04-12 10:42 BST+0100 |
