[SOLVED] Are the fans on my noctua nhd15 facing the right way?
Are the fans blowing/moving air from the front of the case to the back? If so then it should be correct... if not then change it so that all airflow is from the front of the case (intake) to the back of the case (exhaust).
What way?
Air moves front to back, and both fans should be facing the same direction (not blowing into one another).
This is the back of the fan:
I have just posted a pic, the arrows on the fan there,Are they the correct way? Both fans on the cooler the arrows are both facing the same way. Or should I turn both fans the opposite way so the arrows are facing backwards if u no what I mean lol
