[SOLVED] Are these fans compatible with my motherboard?
BigFhungus
7
Hi I am looking to replace the fans in my PC and I want to know if they are compatible with my motherboard, here are the fans I am wanting to get, my motherboard is a Gigabyte GA-x58a-ud3r, and i am using windows 10. if they are not directly compatible what can I use to make them compatible?
Thanks in advance,
Thanks in advance,
I'm afraid that your MB doesn't have RGB header or controller needed to plug fan light in so you would need a dedicated RGB controller/hub.
Thanks in advance,
