Are these temps normal for firestrike?
bobbypie67890
132
I7 5820k@4.5ghz
2x G1 Gaming 980 Ti's +100 mhz core +125mem +12v
Asus x99 Sabertooth
16gb 2400mhz Ram
850 Evo 250gb ssd
3tb Toshiba 7200 HDD
Corsair Rm1000I
H100i Gtx
I was just able to get my graphics card up to 91 degrees by using firestrike ultra and customizing it even more demanding than the stock settings.
I have 3 intakes and 3 exhausts.
I have ~1 inch between my cards but i might be able to move down another slot.
So are these normal?
I think the cards are ok still. Run heaven benchmark. See what your gpu usage is at. If its 90+ on both its the vsync issue. 72 is fine for temps. Again you're running sli. Heat is a big issue. That's why I'm on water, and that's why my buddies 980tis didn't last 2 days before they got water cooling.
Also, I managed to uncap bf4, and I avg 180 fps but get down to 150? I am really about to ditch gaming all together because I don't remember the last time I sat down to play a game and did not have to worry about performance.
if your benchmark scores are where they should be, your other issues can be explained by sli. if your frames drop down for a second or two that's not a huge issue at all. ive had it before. its just an sli glitch. sli has come a long way but isn't perfect. also at 1080p your gpu setup is such overkill the cards probably aren't being stressed enough to really shine. I would honestly say youre fine as long as you can control your temps. turn off your overclock as you don't need it and just enjoy. your games are FAR from unplayable. if you want to swap to ref card sure your temps will be better but performance will probably be the same. have you checked to make sure your cards arent throttling during game play? are you monitoring your clocks realtime during gameplay on another monitor or with an on screen display?
realtime but for example tomb raider, im supposed to get 250+ but im in high 100's and sure i can only see 144 but the fact that I cant even hit that is making me feel really shitty about this computer
