Are this temps safe for ryzen 1700? They looks unveliable for me
WaterKnight
Commendable
Jul 1, 2016
51
Hi,
All my monitoring systems say that my CPU is at 14-16ºC while idle and the temp of the room is 27ºC right now. I attach you pictures.
Temps of my room:
http://imgur.com/a/FOwFi
Temps of my computer:
http://imgur.com/a/LhYGN
Specs:
CPU: Ryzen 1700 OC 3.9GHz (Last Pstate)
GPU: Rx 480 8gb ddr5 reference
RAM: GSkill Flare X 2x8GB DDr4 3200Mhz
AIO: Cryorig A80
CASE: Corsair Carbide 400C
Motherboard: Asus Crosshair VI Hero
I am looking forward to hearing from you. I'll be very gratefull If you help me.
Yours sincerrally.
New system build last month. All the info is above. I have edited the specs. I am using this BIOS: official UEFI 1401.
I have adde the specs above and my bios version is: official UEFI 1401
Does not change my answer. The cpu has a 20c offset that's why you are seeing those temps, perfectly normal.
How can i disable the offset?? Is completely normal ?? I have an Asus Crosshair VI Hero. I have heard that 1700x and 1800x have offset mode but not heard that of ryzen 1700.
Latest posts
