Question ARGB brightness/current problem CoolerMaster
Oct 18, 2020
hi guys,
i built my PC two days ago and connected 9 white MF120 halo fans to the ARGB controller in groups of three, along with the argb of my aio pump (Deepcool Castle 360 ex Snow).
using the argb controller from CM https://www.coolermaster.com/catalog/coolers/rgb-accessories/argb-led-controller/
EDIT: so it seems that I've just got too much going through a single hub, I can't find the exact amp specs of the hub, but one mf120 halo fan can pull up to 0.8A of power, which is a lot and I'm guessing this hub isn't capable of delivering 9A.
My follow up question would be if there IS a hub out there capable of delivering around 9A of power, OR if it's possible to connect two hub's trough a single header for data, each with their own sata power so I'm able to balance the amp's needed to power all of this
Thanks!
