You are right - that mobo does not have an ARGB header you can use. However, the case comes with an alternative you CAN use to get light displays and change them manually. See the manual, p. 10 and 11. p. 10 shows the ARGB Hub unit that comes with the case. You plug each of the 3-hole ARGB LIGHTING cables from the fans into the outputs of that Hub. Then you do NOT connect the two-headed cable that would go to a mobo ARGB header. Instead, you use a different cable that comes down from the switch mounted in the top front of the case (see p. 11) into the two-pin connection at the top corner of the Hub. Using the instructions of p. 11 you can change the lighting displays by using the LED button on the case top.
