I recently installed the artic freezer pro on my Asus p6x58d preimum m/b, since my CPU started overheating. I have 12gb RAM and the fan part is blocked by a RAM stick, but I was able to raise the fan portion a few inches for clearance. The fan is still attached and I started up the PC and the fan runs well and the CPU temp was approx 28c, but I was reluctant to start playing a game before I knew if this would be an issue. I could possibly rotate the fan, so its not blocking the RAM slot, but I was afraid this may be a bigger problem and if I did this, would I then need to replace the thermal compond, even though it was just installed today? Any help would be appreciated.
