R ryannryezamora Nov 2, 2018 2 0 10 Nov 2, 2018 #1 im asking which is more faster ... windows10 2gb ram with 64 bit or windows 7 4gb ram with 32 bit? hope someone will answer ... thanks
2sidedpolygon Prominent Jul 1, 2018 775 0 660 Nov 2, 2018 #2 There's a LOT more to it than RAM, but I don't imagine Windows 10 with 2GB would even be able to run without resorting to using the drive, so the Windows 7 one would be faster. Anyway, could you send what computers you're looking at in particular? Upvote 0 Downvote
Barty1884 Retired Moderator Apr 16, 2015 22,250 1,350 108,740 Nov 2, 2018 #3 All else being equal, the 4GB + Windows 7 would most likely be faster. W10 is a little lighter, but not to the point it'll make up for half the memory. Any particular reason you can't use 4GB + Windows 10? Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 171,472 17,926 184,590 Nov 2, 2018 #4 MERGED QUESTION Question from ryannryezamora : "asking for faster system" ryannryezamora : im asking which is more faster ... windows10 2gb ram with 64 bit or windows 7 4gb ram with 32 bit? hope someone will answer ... thanks All else being equal, whichever one has 4GB. Either OS, either bit level. 2GB is just barely enough to get it running. Upvote 0 Downvote
skywalkerqq Honorable Nov 5, 2017 73 1 10,665 Nov 2, 2018 #5 windows 10 uses around 4 gigs for background processes, i do not recommend it at all Upvote 0 Downvote
Barty1884 Retired Moderator Apr 16, 2015 22,250 1,350 108,740 Nov 2, 2018 #6 skywalkerqq : windows 10 uses around 4 gigs for background processes, i do not recommend it at all A little excessive there. I'm running W10, Chrome with 6-10 tabs open and running Citrix...... and I'm just barely exceeding 4GB. Upvote 0 Downvote
skywalkerqq Honorable Nov 5, 2017 73 1 10,665 Nov 2, 2018 #7 Barty1884 : skywalkerqq : windows 10 uses around 4 gigs for background processes, i do not recommend it at all A little excessive there. I'm running W10, Chrome with 6-10 tabs open and running Citrix...... and I'm just barely exceeding 4GB. youre probably right, i have extra software that checks for malware and that runs system specs Upvote 0 Downvote
