ASROCK 890GX PRO3 with amd fx 6100 after bios flash and NO POST
Saber_1ST
23
hey everyone,
i have a big problem and it is:
i flashed my default bios to the latest version with amd sempron 145. then i turned of my pc, disconnected power cable and replaced the sempron with amd fx 6100 BE. after that i trned my pc on and i got no post and error code 84 and sometimes 1F error code.
oh and one more thing when i use my sempron cpu pc works fine.
PC SPECs:
cpu: amd fx 6100 / amd sempron 145.
mobo: asrock 890gx pro3 am3+.
gpu: xfx radeon hd 5450 1GB ddr3.
ram: 1x4GB kingston ddr3 1333mhz.
psu: low end atx 550 (just for you to know it has only 4 pin 12v cpu cable)
PLEASE guys, fast reply i am in desprete situation :bounce
SORRY for the late reply. i have notices that with the sempron it passes "4d" debug and boot fine, but now with the fx it is stuck in this "4d"error.
The memory controller is on the CPU; I still doubt that it works fine. In the end you'll probably have to return it and get another one.
THANKS for the for the suggestion.i'll look for another PSU with 2x4 pin 12v cable. and i will tell you whats new.
