Question AsRock B650m RS Pro WiFi CPU and DRAM redlights. Can't Post
michael_705
25
Specs
CPU: Ryzen 5 7600x
MoBo: AsRock B650m RS Pro Wifi
RAM: Tgroup T-Create expert (2x16GB) 6000MHz
PSU: ThermalTake Toughpower 80+ gold 850w
CPU Cooler: DeepCool AK620
SSD: Samsung 970 Evo 2TB Gen 3
I just recently tried putting this build together and I'm stuck at a CPU and DRAM red light. I've tried each ram stick in every slot and that was unsuccessful. I reseated my CPU and double checked the CPU power cable and it is in snug. I have completely rebuilt my Pc from the ground up again double checking wires and cables and I do not believe im missing anything. My 24 pin connector will not come out of the socket so i have left that in. I have tried hard to remove it but im to scared i will break something with how much force it is requiring. Would a BIOS flash back maybe help this issue? has anyone ever been stuck with these two red lights?
Slots A2 and B2.
Did you inspect the CPU's socket for any bent or broken pins?
Reduce the amount of mounting pressure on the cooler by performing a few anti-clockwise turn on the mount, see if that helps.
Just make sure that it's fully seated into the connector.
Got a link to this PSU?
