[SOLVED] Asrock G41M-VS3 Ram Running at 1000 MHZ
Dec 28, 2020
6
Hi
I recently upgrade my CPU to Core-2 Quad 9550@2.83 GHZ. I have installed two 4gb DDR3 ram (total=4*2=8 Gb). The problem is my ram running at speed of 500MHZ (Please look below photos).I think it should run at 1333 MHZ speed but i don't know much about it that's why all Bios settings are by default.
Can you please help me to get proper ram speed for this PC? is it can work only 1066 MHZ?
And after checking the motherboard features it shows 1333(OC) for DDR3 so, if i upgrade my Ram at 1333Mhz will it burn or can have any damage? Also i don't know any voltage or anything i should change for get proper speed of ram.
For your kind information My bios is updated. FSB jumper set to 2-3 pin & CPU FSB 1333 MHZ.
Motherboard-http://www.asrock.com/mb/Intel/G41M-VS3/
Please have a look on the Photos.
Bios Pic1-https://prnt.sc/10arek5
Bios Pic2-https://prnt.sc/10arelm
Bios Pic3-https://prnt.sc/10arems
CPU Z- https://prnt.sc/10argeo
Ram Slot1-https://prnt.sc/10argfp
Ram Slot-2-https://prnt.sc/10arghy
Please let me know anything else you need.
Thanks again.
Hi
Thanks again.
Times what what you see in cpuz x2
Hi
Thanks again.
Pic3.....set the ram speed to 667...........test
