I have a problem with my Motherboards' usb ports. Every time I plug in a USB , the USB is not recognized, also it does not give me a notice like"USB is not reconized"
If the USB driver isn't there I'm really not sure what to do. Go into your device manager and see if there are any yellow triangles with ! in them and let us know what section that those are under.
I see no USB drivers and only my two front panel USB are showing
More of a case of you have not turned on USB 2.0 support in the bios of the board. since the four back ports are USB 2.0 standard. If your are using a 2.0 Usb device without the option of 2.0 usb support turned on in the bios the device will not be seen by windows or the USB 2.0 ports.
Once done it may require you to find the driver for the usb 2.0 ports for the board.
It will work then.
It will work then.
