Question ASRock X570 Steel Legend - No Post / PSC Boot LED is lightning
Mar 20, 2020
4
Hi Guys,
I´m not able to get my new PC build run.
ASROCK X570 Steel Legend
AMD Ryzen 3900X
G.Skill 32GB Trident Z Neo DDR4-3600MHz
Corsair MP600 PCIe 4.0 NVME SSD
AMD 5700 XT (was already runningin my old machine)
When I start the computer I get no screen / post. on the PSC (Post status checker) only the Boot LED is lightning. At startup CPU und DRAM are lightning for some seconds than it goes back to BOOT LED only.
What does the Boot LED mean? I´ve tried it with and without the PCIE NVME.
There is no further information about the PSC in the manual.
I also tried a differernt RAM and 3 different GPUs in summary.
Hope anyone can help me.
Thanks
toto1988
Boot should mean storage not working right or disconnected
Try booting with a windows install USB drive.
reset the BIOS by jumper (shorten the clrCMOS pins while power is unplugged from the wall)
Which power supply are you using? brand and model please
The RAM is installed into slots A2 and B2?
Did you connect the monitor to the GPU and not the motherboard´s video ports?
In which M.2 slot did you try the nvme storage?
Hi helpstar,
thanks for your reply.
it doesn't matter if there's an ssd plugged in or not
not working....nothing happen
I did it by removing the battery
Enermax Revolution X´T / ERX530AWT
BeQuiet PowerZone 1000W
yes
I´m sure that the monitor is connected to the GPU
Slot 1 - directly under the GPU
Did you try a different hard drive? connected by SATA
Did you try a different M.2 slot?
check the pins of the removed CPU
also your memory is not on the compatibility list of the motherboard, might be incompatible to your system. Which other RAM did you try? If this would work, eventually a BIOS update will get you more compatibility.
EDIT
Try a different video port of the GPU. How is it connected to the monitor?
Wait about 2 minutes after powering on the PC, maybe it needs more time
I also tried a different NVMe, a SATA device and different DDR4 RAM. Tried both M.2 Slots.
and I tried the components on a different motherboard --> Gigabyte X570 Gaming X --> No POST, No Screen,
Hi toto1988.
Did you resolve your problem? Have have run into a similar problem and would like any advise if you were able to solve it.
System:
Asrock x570 steel legend,
ryzen 5 3600,
rog strix 5700xt,
tridentZ neo F4-3600C16D-16TZNC
970 evoplus as bootdrive
The system was running fine (built in the end of last year) until it blue screened on me twice back to back and now it is stuck on the red boot LED.
Any advise would be much appreciated
