AsRock Z170 Extreme4 1151 Skylake Dr. Debug 00, No Display, and No Post
Dean5000
29
Hi, I've been getting this Dr. Debug 00 error, no display,and no post or beeps (I used the old small speaker from my previous build on the new motherboard, so I only think that I've got it plugged in the right place) upon booting up my new pc build for the first time. It's a completely new build made up of:
I7 6700k CPU,
ASUS STRIX GeForce GTX 980 Ti,
AsRock Z170 Extreme4 1151 Skylake Motherboard,
Hyper Evo 212 CPU Cooler,
Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4 2400 Mhz,
2 x Samsung 850 EVO 500 GB 2.5-Inch Solid State Drive.
EVGA G2 1300W Power Supply
Dell U2515h 25 inch 1440p Monitor
I've built another pc before a few years ago, and it worked fine straight away with only one small mistake, yet this one I have run into this stressful problem I can't seem to solve despite searching online everywhere. I have done countless CMOS resets, reseated my cpu and cpu cooler a few times, while reapplying thermal paste, I finally gave in and returned my motherboard for a replacement, andthe same error still appears, so it can't be a dead motherboard. I have tried installing my old power supply to see if the new power supply is also dead, but the same error happens, but both the old and the new power supply's fan does spin, and everything that is connected to the power supply directly, such as the graphics card and SSD drives all startup, as in the graphics card lights up and its three fans all spin, and there are startup noises coming from the front of the pc too, (not sure if the noises are from either the SSD's or from the optical drive). If i plug the case fans into the power supply through the molex cables, they al start up full speed too, but if they are only plugged into the fan headers, they don't start up at all, suggesting that the power supply again must be fine I'm guessing?
I've tried removing the graphics card and plugging the monitor into the motherboard Display port slot, and still nothing issolved. The only things left I can think of are that either my CPU itself is damaged and needs replacing, or that my RAM could possibly be incompatible with my motherboard? I did look on my motherboard's website and I couldn't find my exact model RAM on it's compatibility list, but there was very very similar model numbers to mine in that list, so I'm hoping they're compatible.
So if anyone can help me I would be very grateful, thank you!
EDIT: Turns out it definitely isn't my Power supply or my Graphics card that is the problem, as I've just rebuilt my old pc using the old motherboard and CPU, but also using my new power supply and graphics card too, therefore they both work flawlessly. This definitely leaves it down to either the motherboard, CPU, or maybe RAM (?) in which is the problem, though if it's the motherboard, it will be the 2nd time i'd have to get a replacement...
SOLVED EDIT: I already posted a while ago how i solved this problem at the end of this thread, but thought I'd now update this main first post, so any new readers don't have to read everything to the end to find the answer, so: I can confirm that it was my cpu that was faulty all along!!! I've finally got my new pc fully fixed and as soon as I installed the new processor that arrived today, the pc showed a full monitor signal and my bios was fully showing. Now I've been reinstalling applications and things and have nearly got everything from my previous hard drive copied over, so thank you again to everyone that has helped me! :) Hopefully this thread could be useful to someone else who has the problem I had.
This means that the Hyper EVO 212 doesn't create any problem with ram slots on your mobo?
Sorry about OT but i got exactly the same configuration and i was wondering about the Hyper EVO dimensions on this motherboard.
Thank you
Sorry Gattamelata75, I hadn't checked this thread ever since I got my computer fixed, so I'm sorry for the extremely late reply and I'm guessing you've already solved your question, but yes the ram modules do all fit fine with the Hyper Evo 212, the only way the Hyper Evo gets in the way is when inserting and removing just the 1st ram slot (It's nearly impossible to insert/remove the 1st ram module), but this is easily solved by just temporarily removing the clippable fan of the hyper evo 212 beforehand. Once the ram module is fixed into the 1st slot, the Hyper evo 212's large fan actually sits just a small gap above the ram module leaving enough space to not get in the way of it.
Make sure you have connected a 4 or 8 pin power connector from your PSU to the MoBo just above the processor. It's a common error in new builds. The board lights up without it, but the processor won't have power.
