[SOLVED] ASRock Z270 Pro4 - Help
Mislav_1
39
Hello there. I am planning on removing my current KINGSTON 16 GB (2x8 GB) DDR4, 3000 MHz, DIMM, HyperX Predator, CL15, HX430C15PB3K2/16 ram and selling it to a friend.
I was looking to get one of this:
G.SKILL Trident Z Neo 32GB (2x16GB) DDR4 3600MHz 288-Pin CL 16 F4-3600C16D-32GTZNC
G.SKILL Trident Z Neo Series 32GB (2x16GB) 3600Mhz 288-Pin RGB DDR4 F4-3600C18D-32GTZN
HyperX Fury RGB 32GB (2x16GB) 3600MHz DDR4 CL17 HX436C17FB3AK2/32
I did check website for my motherboard and non of this are listed. I know there are a lot of different kits and it's impossible to test all of them. I did ask some friends, but I want to be sure if one of this will work on my motherboard.
I know this sets are RGB and if RGB doesn't work, it wouldn't bother me, as long as they work normally.
