Asrock Z87 Extreme4 Ethernet issues.
qId3r
4
So a few weeks ago I got a pc to game on and up until now I have had no issues. Basically, it won't connect to the internet. When I have an Ethernet cable plugged in it doesn't register on the pc but when I plug that same cable into my xbox it works fine. I have tried uninstalling the drivers and reinstalling off the disk but still nothing. Has anyone had the same problem? And also when I go into device manager it says it is working fine so could one of the contacts come loose?
Other pc specs:
Haswell I5 4670k
Gigabyte gtx 760 oc windforce
Thermaltake Evo blue 750W gold
It would be under warranty but I'm not sure if I should bother sending it all the way back when I could just get a network card.
Yes the card is cheaper
