I just finished building my pc today and I'm not sure if my cooler is hooked up wrong or it's just a software bug/issue
Cpu is - i5 10400
My motherboard is - ASUS TUF B460M-plus wifi
Cpu cooler is - thermaltake UX100 rgb
Case is - Asus TUF Gaming GT301
So my issue is after hooking everything up I can get aura sync to work on everything (motherboard, fans, gpu, ram) BUT not the cpu cooler. The cpu cooler does work if I use the case's button to control the lighting but if connected to the mobo and/or case controller (I've tried both), it just goes into factory rgb rainbow effect.
The only time I can get it to somewhat work is if I just hook up the D/signal wire without the ground wire on either the mobo or case controller, but it's like a grainy signal ex: set aura to purple breathing and only hook up the D wire then it does a half ass purple with some rgb mixed in (like it's shorting out the signal) if I have both D and Ground hooked up then I lose ALL aura sync compatibility it seems.
And the way I have it hooked up is cooles is hooked up into cpufan controller and then the extra D/G wire into the argb hub, the fans (that do work with aura) are all just hooked straight into the hub.
If anyone has any ideas please let me know, I'd like to be able to use aura and not just the standard case settings and then have to play with aura to match everything g.
Cpu is - i5 10400
