Hey everyone.
I just tried building my first gaming desktop with the following specs:
Case: Rosewill Challenger
CPU: AMD Athlon II X3 440
RAM: Mushkin Enhanced 2x2GB DDR3 1333
Graphics: ATI Radeon HD 4870 (x1)
Monitor: Haans-G HZ201 20" 5 ms LCD
MoBo: Asus M4A87TD Evo AM3 USB 3.0
HDD: Samsung HD502HJ 500 GB 7200 RPM 3.5"
ODD: Optiarc Lite-On
It started first time, except for some reason it locks up over and over. In the middle of installing any OS (tried Win7, Vista, Ubuntu 9.04) it gets to the "Expanding Files" section (in Windows, specifically) and just freezes. I ran MemTest86 for an hour or two and found no problem with the RAM. I tried booting it with one stick instead of two. I tried plugging the HDD into a friend's, which installed Windows 7 just fine, but then locks up a couple minutes into the desktop when I put it back. I tried reconnecting the hard drive to a different SATA port. It still locks up.
Then I looked up a known issue between F3's and Asus MoBo's, but everyone's complaint is that their BIOS doesn't recognize the HDD. Mine recognizes it fine, knows its model number and specs, but just freezes. They all recommend this Samsung release:
http://www.samsung.com/global/business/hdd/faqView.do?b2b_bbs_msg_id=308
to run from a bootable DOS flash drive/CD-ROM. Not only do I only see F3.exe and F3EG.exe on that site, but when I boot the file for my drive from a DOS drive and type DIR, enter, F3.exe, enter like it says, it gives me this:
"SFlash V5.32 Samsung Electronics Co Ltd. 2000-2009
>>C:/F3.exe @23:06
[1002h/4390h] B=0 D=11h F=00h H=00 C=01018f....ATI SB700 SATA IDE
{0} [Samsung HD502HJ (1AJ10001)]....ATI SB700 SATA IDE Ch:1 DEV:0
This program isn't available for this drive."
..and now I'm back to square one. Does the SB700 mean I shouldn't be having incompatibility issues in the first place? What else could cause this freezing over and over? Where is this ASUS.EXE they keep talking about?
>>C:/F3.exe @23:06
