Asus geforce6600GT AGP overclocking help!
grunt123
41
i'm planning to buy zalman vf700 cu cooler. can someone please tell me whether this cooler is compatible with asus card? (like, HSI heatsink integrated into stock cooler for this asus card? will i be able to put ram heatsink with the zalman cooler?)
hmmm ... if that's true, then it's better to look for another cooler ... Do you know any good cooler that will be compatible with geforce6600GT agp? Not many coolers are compatible with this type of card.
The Vantec Iceberq 5 is due to come out later this month and should fit it. There is a variant of this cooler produced by JetArt that is already on the market.
I also have an asus 6600gt and have just fitted a vf700-cu due to the stock fan making constant annoying noises. The top fins sit about 3-4 cm over the top of the card and the supplied ramsinks don't fit but other then that I had no problems.
With the stock h/s at 600mhz my temps were around 44 idle 77 load. The vf700 made a huge difference with the core clocked at 620 I now get 31 idle and 45 load. I haven't tried going past 620 yet but should hopefully be able to push it even further. Most importantly it is also nice and quiet unlike the asus one.
If you do plan on using that cooler, I would be extra carefull when moving the PC.
<font color=red>"Battling Gimps and Dimbulbs HERE at THGC"</font color=red>
"<font color=blue> Wusy</font color=blue> <-Professional sheep banger"
I think they have an artic cooler compatible with the 6600 right? if anything thatd be my choice better case temps also, and never heard a bad thing about them except people that dont know how to install it and didnt put thermal paste under the heatsink gave it one star!!! bastereds...j/k
Asus A7N8X-Deluxe (Nvidia Nforce 2)
AMD AthlonXP 2500 at 3200 (stock voltage)40c Load
Coming soon: Nvidia 6800 vannilla
Antec TruePower 400 watt ps
1x256 Meg Corsair ValueRam 2.5,3,3,7
go wusy! lol
I Don't think arctic cooling make a cooler that is compatible with the 6600gt AGP only PCIe.
From their compatability page
NV Silencer Compatibility (on Nvidia boards)
We have no cooler for the 6600GT AGP board.
http://www.arctic-cooling.com/vga2.php?idx=62&data=7&disc=
