ASUS H170 Pro Gaming motherboard solid red DRAM LIGHT
Sharp104
9
I'm working on my first build, using the Asus H170 Pro Gaming motherboard and the ram light shows solid redd whenever I attempt to start it. I don't ever reach a bios screen or anything. I'm using hyperx Fury 2x4GB 288 pin ddr4 with a speed of 2133, which I believe to be compatible. What mght the issue be?
Ram inserted correct?, try swapping sticks around? bios reset?
I've swapped sticks around in several combinations, as well as using only a single stick at a time, and the ram is inserted correctly and completely from what I can tell. I'm new to PC building, so I might be missing something obvious, but how do I reset bios without being able to boot with any display?
Try to talk with Asus Company or from where did you buy it as that could be wiring faulty.
Did you ever find a resolution to this? I've just bought the same motherboard and am having exactly the same issue.
Same problem also for me, news?
