Asus H81M-K running hot
chienetfou
61
Speccy lists the motherboard temp at 250 F. This seems a bit hot to me so I thought I would check with others that have a bit more knowledge. Asus wasn't much help. The socket is 1150 running an Intel Pentium.
Thanks
what is your , gpu and cpu temps ,,,,
250 F is equal to 120 D, it is actually four times the normal working temperature of a mobo,. i came to know my actual temps when is used iobit advanced system care's monitor ..still speccy shows incorrect reading
IdSKhxGA-VA2pHEMq-E153O4jgbuZvVJYFWR8U9CU4iaox0bUi6eDJDE0ue79wmeGkQwnuinMCP5e-Q=w1678-h717
unfortunately the asus ai suite that is part of the software for that board doesn't include a sensor for the board temp. any recommends for an alternative program?
