Hello,
I just replaced my motherboard with a M2A VM, which I got factory-packed as an RMA-replacement from ASUS. Fittet it with 2 GB RAM, Samsung HDD and an Athlon 64 X2. When I turned on the system for the very first time it stopped on POST, with no signal going to the monitor. Upon hitting the reset button, it came up again and this time started booting, but halted with a screen saying "Boot failure, continue or enter setup to restore default values". From there I could start the machine, installed OS, set up programs and all.
Strange thing now is, that every time I turn on the machine after it had been shut down for a while it will hang at POST, but after a reset it will restart, get to the abovementioned error page and then boot into Windows just as if all was normal. I have tried resetting the Bios to default values, I have updaten the Bios, I have changed boot orders, but that did not change a thing. The POST-problem keeps coming up, although only after booting up after the system has been switched off completely for some time.
Any hints as to what might be the problem are highly welcome!
