Hello there and I just got all my new parts for my computer and am having trouble with it. The following is a list of my parts:
Asus M4A87TD Motherboard
AMD Phenom II X4 970 3.5Ghz, Quad-Core, 8.0Mb Total Cache, Socket AM3
3x 2Gb DDR Corsair XMS3 (CMX6GX3M3A1333C8)
Nvidia GTX 460 Graphics Card 1024Mb GDDR5
OCZ Fatality 750W Power Supply
Western Digital 1.5Tb Sata Hard Drive
CD/DVD Burner Drive from my old computer
Problems:
No POST
Nothing appears on the monitor
The DRAM_LED Lights up when I start on the computer then turns off.
The CD Drive appears to not have power despite hooking up a cable from it to the Graphics Card. (It won't open up or blink its LED light)
Startup gives me 1 Long Beep,3 Short Beeps and then another beep after about a 2-3 second delay after hearing the 1 long and 3 short. I cannot find the beep code table in my manual.
Random Notes:
I have tried booting with 1 stick of RAM and I get the same beep message. Removing all the RAM gives me a different message. I think it was like 1 Long 1 Short continusously.
I don't know if this has anything to do with it but I have an IDE cable connected from my motherboard (blue) to the CD Drive (Black). The CD Drive does NOT have a SATA port. My Hard Drive is connected with the Sata Cable and placed in slot one for the Sata ports on the motherboard. I also connected the front panel SATA port to the second Sata port on the motherboard.
***EDIT***
Found the problem through more trial and error. The Graphics Card I ordered was DOA. This took me 3 times of swapping graphics cards back and forth to finall get a POST.
Problems:
No POST
Random Notes:
***EDIT***
