Hi, I have above mentioned Asus P8H61-M PRO/V-P8H61E/DP_MB motherboard to replace my old, dead one. But after set up - it won't work - even signal to the screen is not going through. Changed graphics card, reset BIOS. CMOS. Have disconnected everything not needed - dead. So question arises - does it actually support 3rd generation intel cpu's? When I was buying it - I assumed that first part - P8H61-M PRO is the actual motherboard model, but just recently noticed that they are different. The last one cpu support list does have my cpu listed (i5-3570k 3.4GHz) but as the motherboard looks different 🙁 It's all very confusing. When I talked to seller - his answer was - he tested it with 2nd generation cpu - respectively - he thinks it is working. Is it possible that I need to update BIOS, but how can I update BIOS, if I can't even get in to the BIOS? Thank you for help in advance...
