Question ASUS Phoenix GeForce GTX 1060 6GB GDDR5 fan speed and fitting.
DonoDonato
44
Hi,
i saw a great deal on this card ASUS Phoenix GeForce GTX 1060 6GB GDDR5. Unfortuantgely there is almost no reviews, youttube videos about it. Even Asus website gives almost no information about it.
If anyone has it could you answer any of theees questions. Would be appreciated.
  1. Does the fan turn off automatically when GPU is in idle temps? Maybe someone knows what is that temp (i.e strix shuts down below 55c).
  2. Card is 3.8 cm thick. Has anyone actually tried to fit it into mini-itx case?. Seems it will amost touch the PSU. I assume fan is on the bottom. Will it be noisy sucking air off the PSU's surface?
  3. Any other notices/warnings/encouragements about this card? There's nothing ouit there.
Thanks a lot guys.
  1. my zotac 1060 kills the fan below 40c and stays around 30c at idle, so i guess yours should behave similarly +/-.
  2. i have a mid tower so not sure, but the 1060 line is generally compact.
  3. i think all 1060s dont support sli, mine does not.
