W waholi Distinguished Dec 31, 2011 107 1 18,695 Mar 3, 2021 #1 I have ASUS PRIME H310I-PLUS which way do you put the pin connectors for F-panel? https://photos.app.goo.gl/G3iwjQxTEpeQ2rCe8 thanks in advance
Solution Nemesia Mar 3, 2021 Look on the connectors for a triangle molded into the plastic. Those will be your positive.
Gam3r01 Titan Jan 12, 2013 25,414 973 115,440 Mar 3, 2021 #2 What do you mean which way? Upvote 0 Downvote
Nemesia Splendid Nov 6, 2019 5,778 1,240 29,390 Mar 3, 2021 Solution #3 Look on the connectors for a triangle molded into the plastic. Those will be your positive. Upvote 0 Downvote Solution
