Merry_Blind :
Ok, let's forget consoles then for a second, because I didn't think of the fact that they can't output at 120hz. If, for example, I had my PC hooked to the Swift monitor, set to 120Hz, and that the game I play has a fluctuating framerate going anywhere from 30fps to 90fps. Would I be able to use ULMB since the monitor is running at 120Hz? Despite the framerate being all over the place, and not ever at 120fps?
Thanks for your reply btw.
No problem. I enjoy discussing the topic.
Yes. You would. Because with ULMB on, the REFRESH RATE stays constant, despite your varying frame rate. The monitor (In regular, or in ULMB mode, with Gsync off) will only refresh the frame at a rate of every 8.33 ms (1 / 120Hz), regardless of your framerate. This has nothing to do with the 1ms response time. That's where your keyboard or mouse input lag comes in. This is also what causes horziontal tearing, which is what GSYNC aims to remove. If your FRAME rate is much higher, or much lower, than your monitor's REFRESH rate, you will observe lots of tearing. ULMB does not reduce tearing, just motion blur.
