Hi,
I've just built the following and am tearing my hair out because it won't stay on for more than 5 mins. I can't get Windows to install because it just bums out while trying.
Has anyone got any tips or suggestions?
Windows being installed off a USB
ASUS Prime B450M-K Micro ATX Motherboard (I've updated the BIOS)
AMD Ryzen 5 3600 Processor
Western Digital WDS500G2B0A WD Blue 3D NAND Internal SSD 2.5 Inch SATA, 500 GB
Corsair VS650 650 W Active PFC 80 PLUS Certified Power Supply Unit (I've tried just using one stick of RAM)
2 of Corsair CMK8GX4M1A2400C16 Vengeance LPX 8 GB (1 x 8 GB) DDR4 2400 MHz C16 XMP 2.0 High Performance Desktop Memory Module
MSI NVIDIA GEFORCE GTX 1050Ti 4GT OC Graphics Card
I either get a blue screen saying it ran into problems, or I get "Windows cannot install required files. Make sure that all files required for installation are available and restart. Error code 0x8007025D"
The funny thing is that when I take one stick of RAM out, it lasts double the time before it crashes. Not sure if this is pointing at a RAM issue or not.
Thanks
Chris
Thanks
Chris
