[SOLVED] Asus Tuf 705DT - Stuttering in stress test when charger not plugged in?
Rutwick
28
I am looking to buy a used laptop, an Asus Tuf FX 705DT which has a Ryzen 7 3750, GTX 1650, 8 Gigs of single channel RAM and a 512 GB SSD, less than a year old. I did some stress testing on it with Aida 64. Everything seemed fine, until I removed the charger. The laptop started stuttering very badly on removing the charger. Is this occurrence normal in stress tests, and could it be because of the RAM quantity?
I have done all checks including benchmarking and temps, everything looks good. Is there another test that I need to do to see if the laptop is fine?
disconnecting charger usualy means that laptop switches to low power mode, stuttering is expected
can be configured for high performance even on battery...but it wont run for too long before battery dries
