Hi all, links to the mobo and CPU I bought are below. I'm a fairly experienced PC builder, and I've done all the troubleshooting I know (unplugged all peripherals, graphics card, etc.), QLED for diag seems to work, when power goes to mobo RGB lighting turns on and actively undulates. QLED diag is functional, tested by removing RAM from DIMM. I made sure the power switch was wired to the header correctly, and despite power getting to the mobo it just won't power on.
I have a 3090 GPU, Ryzen 7-9000 CPU, and an 850w PSU. I ordered a new 1000w PSU in case this was the issue. I know the case/pwr buttons work as I'm simply replacing the mobo/CPU in previous ATX case.
I just got the mobo from Newegg today, but I hate to return it if I don't have to. Is there anything else I can to to troubleshoot? Thanks!
https://www.newegg.com/p/N82E16813119686?Item=N82E16813119686
https://www.newegg.com/amd-ryzen-7-...cessor/p/N82E16819113843?Item=N82E16819113843
