Question Asus TUF x570 wifi pro AMD bracket not installed when the builder installed a corsair water cooled system ?
Mar 28, 2022
4
Hi Everyone,
I hope someone can help with my issue. The builder of my pc, installed a water cooled fan system corsair H60i. but he installed it directly on some standoffs, instead of the AMD clip brackets https://imagebin.ca/v/6bqDFKLxOeG5
current bracket installed is https://imagebin.ca/v/6bqChbk0l3eG (directly standoffs on the motherboard) but the new water cooler i'm trying to install is the masterliquid ML240L V2 RBG which doesn't have the supported brackets to install it on my current setup which I have.
To do so , i would need to the following brackets https://imagebin.ca/v/6bqDFKLxOeG5 which were removed by the original builder.
My question is, does anyone have a clue which brackets would be required to install the CoolerMaster ML240L on my existing standoffs or is there some where I could get these https://imagebin.ca/v/6bqDFKLxOeG5 which are missing and then it would be possible to install the Cooler Master I just bought.
does anyone know where I can buy those AMD clip brackets?
Regards
Stephane Boudreau
