Hi all.
I have an ASUS X670 e I (the mini itx) motherboard that appears to be having some issues, and I'm not sure if I've messed something up or if it's dead on arrival.
I've rebuilt the system twice. It does not power on at all, however, the HIVE (external part of the chipset so that ASUS could cram an X670 into a mini itx form factor) is getting power, and that is connected via usb to the motherboard that will not boot. I'm also not getting any motherboard warning lights (which are on the HIVE) to indicate a bad cpu or RAM. I can press buttons on the HIVE and they turn on / off like they should, but pressing the power button to turn on the computer does nothing.
I have tried using a different PSU and I know from the cooling loop that the PSU it was built with was functioning correctly. I've tried using a different front panel, I've tried hooking the panel power cable to both places the motherboard manual says you can (though the manual could do a better job at indicating where things go). Again, I completely broke everything down and rebuilt it to make sure everything was inserted properly. Nothing seems to be working.
I know all of the parts are compatible. The CPU is a 7950x, RAM is corsair dominator ddr5 (amd expo), m2 is crucial.
Edit: adding system specs below
Case: Corsair 1000D (and a second PC already in case, hence the two panels) and its got a custom liquid cooling loop.
Components for PC that isn't working:
All components brand new.
ASUS X670 e I wifi mini-itx motherboard
AMD Ryzen 7950x cpu
Corsair Dominator Titanium 6000MT (AMD Expo) ram
Crucial T70 m2. Drive
Corsair sfx 750 PSU
AMD Ryzen 7950x cpu
Corsair sfx 750 PSU
