Asus Xonar DG PCI Sound Card vs realtek 7.1 high definition audio
vishalaestro
1,446
i already have a onboard 7.1 supporting realtek onboard audio im using it wih my Plantronics Headset With Mic : AUDIO-326 and entek 5.1ch audio..is it necessary to add a dedicated sound card like Asus Xonar DG PCI Sound Card ..will i get a best experience with my onboard sound card with the above headset and speaker..
the answer would be yes in my experience
having a sound card will deliver a better sound experience
the sound chips used are higher quality than the ones on a mobo
so give better audio quality
Well it's pretty obvious. The Xonar DG has a decent headphone amp, not to mention it has Dolby Headphone (virtual 5.1 surround sound) which sounds great in games and improves positioning. It'll support headphones up to 150 Ohm headphones according to this review: http://www.overclock3d.net/reviews/audio/asus_xonar_dg_review/3
which makes it a big improvement over the on board if your headphones have a high resistance.
my headset and 5.1ch is mentioned above my question is will the asus sound card will make a very much noticable difference compared to a onboard sound card with these particular headset and speaker..
I have an Asus Xonar DG pci card in my system and also good onboard sound
and the Xonar DG sounds better on my Creative T4400 4.1 surround sound
also I use it with headphones and it has a dedicated headphone amp that you can plug
into the front ports of case (HD or AC97) with jack sensing
I am very happy with it
