Z10ped8 ws works fine with e5 2699 v3 chips (2)
However
With approved bios 3204, ram, power supply etc (the same as above)
When I put 2 Intel e5-2699 v4 chips in at the same time, the board won't even boot, dead nothing.
Spare identical board, different e5-2699 v4 chips, rinse repeat: other board works with v3 but won't power on with v4
If I remove 1 v4 chip from socket 2, then it powers up
Went back 6o other board, reproduced the same issue
Both boards work with dual v3 chips, both boards only work with only 1 v4 chip in socket 1.
Asus claims e5-2699 v4 fully supported in bios 3204.
To date I see no evidence both chips can work on the board at same time.
I called Asus, the only feedback I got was try refladhing bios 3204 (seriously)
For sake I did but of course that didn't make a difference
Does anyone have any solutions ???
Side note: v4 chips are retail, there is a similar thread in this forum with the exact same issue but the op is using engineering samples, the few comments on that thread were suggestions that ith4 no power up issue was because the op used ES chips. As I am having the same issue with two id4ntical boards and 4 of the retail boxed v4 chips, chances are his issue was not from Es chips
However
