Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Ok, I just upgraded my pc to an AMD 2800 Barton with ATI 9800 Pro 128meg
video card. Finally switched from Nvidia. First thing that I learned was
that you have to uninstall any prior ATI driver before upgrading to new
driver. Ooophs! Like anyone reads the "ReadMe" files?
Anyway, I open the ATI control panel and select 3D tab. I can either use
the slider to adjust graphic settings or go into Custom. Here's my
questions:
1. How do I force ATI video card to set AA/AF to off? I only see
"manually" set it to min 2x, or let the application set it. For game X, I
want it off.
2. I ran benchmarks on CoD and UT2004. I manually set the AA/AF to 2x
and got X fps. Then I set AA/AF to max. But I still got X fps. This was
in 1024 rez with 32 bit color and max details. My new system might be
fast, but I should have seen a drop off in frame rate when I manually set
AA/AF to max. Even other web sites with their benchmarks show a drop off.
Is there some setting that I still need to flip to kick in my custom
settings? Oh, V-synch is off.
3. If I let the Application pick AA/AF setting, is there a way during
gameplay to tell what the application picked?
4. Under Custom, there's a bunch of sliders. And then there's two radio
buttons: Performance vs Quality. What exactly is this feature doing for
me? I d/l the ATI manual which has some info on 3D settings, but this
feature isn't listed.
TIA
JLC
questions:
want it off.
TIA
JLC
