ATI Sapphire AMD Radeon HD 7950 Dual-X 3GB GDDR5 or Sapphire Radeon R9 280X Dual-X GDDR5 3G
chris_gomez
5
What do you recommend taking it clear that I want to save as much money as you can as I need to change the Mobo. and there is as much difference between the two? since practically amount to the same thing and I'm confused.
connectonight
66
13
Definitely go for the R9 280X since it offers the performance of a Radeon HD 7970 which is notably faster than a 7950. But if you can, I'd advise you to go for a R9 290 since you can find them under $270 now.
