Hey,
anyone have an ati tv wonder pro? If so, are you having problems with it crashing while recording tv?
I've read through ati's faqs and found they dont support HT or dual processors. The only solution they list is to remove one of your processors or turn HT off in the bios (I dont see either of these as a solution).
Is there anyone that solved this problem without down grading their system?
Thanks
if you're gonna be a bear, be a GRIZZLY!!
Thanks
