Audio and Ring Volume
G
Guest
Guest
Archived from groups: comp.dcom.voice-over-ip (More info?)
In the SPA-2000, is there any "soft" way of increasing audio volume and
decreasing ring volume?? Thanks and best regards,
Art
G
Guest
Guest
"artlab" <artlab@bellsouth.net> wrote in message
news:tYx_e.7771$7l.6827@bignews2.bellsouth.net
> audio volume and decreasing ring volume?? Thanks and
> best regards,
> Art
No, it's down to the phone. My phones (BT Converse 2025) both have ring
and audio volume settings anyway.
You might possibly cause a phone to ring louder if you increase the
ringing voltage but I wouldn't recommend it or guarantee it wouldn't break
your phone, so you try it at your own risk..!
Ivor
G
Guest
Guest
Thanks for your reply Ivor. I want to make the ring softer, not louder..
Does this mean that I can lower the ringing voltage safely?
Thanks, and best regards,
Art
"Ivor Jones" <ivor@despammed.invalid> wrote in message
news:3pvpq7Fc0j9jU1@individual.net...
> > best regards,
> > Art
> Ivor
G
Guest
Guest
Is it a mechanical or electronic ringer?
miguel
Hit The Road! Photos from 36 countries on 5 continents: http://travel.u.nu
Latest photos: Queens Day in Amsterdam; the Grand Canyon; Amman, Jordan
G
Guest
Guest
"Miguel Cruz" <mnc@admin.u.nu> wrote in message
news:74OdnejyJu9afKfeRVn-qQ@speakeasy.net...
louder..
> miguel
Miguel, Ivor: It's an electronic ringer. I experimented with lowering the
voltage and there is a threshold around 50 volts where the ringer simply
stops working (which was to be expected). I do not have a ring control on
the phone so I guess I'm going to have to live with it. Best regard,
Art
G
Guest
Guest
news:C1A_e.7793$7l.7285@bignews2.bellsouth.net
> softer, not louder.. Does this mean that I can lower the
> Art
Possibly, but depending on the type of ringer it might just stop working
altogether..!
It really is a phone function, maybe it's worth trying a different phone.
Ivor
A: Because it messes up the order in which people normally read text.
Q: Why is top-posting such a bad thing?
A: Top-posting.
Q: What is the most annoying thing on Usenet and in e-mail?
G
Guest
Guest
news:4PC_e.8604$yl.8379@bignews1.bellsouth.net
[snip]
> with lowering the voltage and there is a threshold around
> 50 volts where the ringer simply stops working (which was
> to be expected). I do not have a ring control on the
> regard,
Or change the phone ;-)
Ivor
G
Guest
Guest
"Ivor Jones" <ivor@despammed.invalid> writes:
> [snip]
>> regard,
If you are going to change it, why not experiment and put a resistor
in series with the ringer unit. What is the worst that can happen?
You can break the phone and you need to change it, which leaves you at
step #1 "change the phone". ;-)
-wolfgang
Wolfgang S. Rupprecht http://www.wsrcc.com/wolfgang/
Microsoft Vista - because "Virus Installer" was too long.
