Question Audio and video going dark suddenly
Apr 30, 2023
I updated my pc parts recently and my video and audio have been dying at random at least once per day. When it happens the other parts like the fans and NVIDIA GPU are still working, and I can't restart the pc without turning off the power switch on the powersource. I've been monitoring CPU temperature and it's not overheating. One suspicion I'm having has to do with the integrated graphics card, since when I was setting up the BIOS it had a similar behaviour of randomly turning off the video, and when I restarted the pc there was a yellow warning on windows device menager. I'm not using it this onboard card for anything, but maybe something with it is affecting my actual graphics card ?
Does anyone have sugestions of what it might be ?
My parts are the following .:
Corsair CX750
ASUS GeForce RTX 3050
Gigabyte B650M gaming X AX
16GB RAM DDR5
AMD RYZEN 5 7600X
Rise Watercooler Black 240mm
SSD 480GB Sata3 WD
Only my GPU, power source and SSD aren't new.
Completely remove the GPU from motherboard. See what happens as far as random shutdowns.
If stable, go ahead and update to latest stable BIOS and current chipset drivers.
Then go ahead and reinstall the GPU and see what happens.
When you say you updated recently, what does that mean? Are you using a previous Windows install?
I meant I updated my setup. Only my power source, GPU and SSD aren't new. I'm using windows 10 and had issues making the motherboard recognize it but that is a know issue that's happening with AMD.
When you say to remove the GPU you mean the RTX or the one that came with the MB ?
