Audio CD's & WinXP
Neil
569
Archived from groups: microsoft.public.windowsxp.basics (More info?)
Exploring an audio CD on my brothers laptop (running XP Home) appears empty,
properties also show zero bytes used (media player plays them ok). I don’t
use XP and didn’t know if this is normal or if there is a problem. He would
like to be able to see the number of tracks and space used as in Win98. Any
help appreciated.
"Neil" <n_hinton@FISHonetel.com> wrote in message
news:4234c90c@212.67.96.135...
> empty,
> properties also show zero bytes used (media player plays them ok). I don't
> use XP and didn't know if this is normal or if there is a problem. He
> would
> Any
> help appreciated.
Audio CDs don't report (I don't remember this ever being the case in 98
either) the size of the disk, since only the time total available on a blank
CDR to burn to Audio format is what matters. If he wants to know the true
size of those files, he should rip them to a folder using the .wav format,
which is the best no loss ratio when recording music to CDs. The bitrate of
wavs are 1411 kbits/sec @ 44000 Hz 16bit (typical settings).
So, a CD that has 60mins of music, converted over to Wav into a folder,
would translate into a total folder size of 677280000 bytes (677.28 megs).
If he wants to calculate the actual size using the total time (use seconds)
and multiply that by 11,228 (1411 x 8bits), and the total will be in bytes.
"Tom" <noway@nothere.com> wrote in message
news:uglUWsCKFHA.2212@TK2MSFTNGP12.phx.gbl...
> > empty,
don't
> > would
> > Any
> > help appreciated.
blank
of
seconds)
bytes.
Thanks Tom,
Win98 explorer showed tracks as Track01.cda etc. and drive properties showed
space used in bytes and MB's, again thanks for your help.
Neil
