[SOLVED] Audio interface only working as input or output, not both
Ashesandwool
Hello, I just bought the RØDE AI-1 audio interface and I have connected my microphone to its input, my speakers to its output and my pc to the interface via usb-c. On my windows 10 pc I have selected the AI-1 as both the input device and the output device, and both of the uses work, but it seems that when I am using it for my microphone, the speakers stop working, and when I am using it for my speakers, my microphone stops working. For example I will start my computer and the pc will recieve input from the microphone, but my audio doesn't work. When I disable the microphone the audio starts playing clear as day. I appreciate any help I can get, because I need to get this setup up and running.
My man, you are an absolute saint, I asked this question on two different forums, I emailed Røde who gave me a stupid answer about "not connecting" my headphones and speakers at the same time and making sure I had selected the right devices. Thank you so much, you have saved me so much time
Reactions: maikutech
