For a few months now, my PC has been experiencing latency spikes. Audio dropouts are exceedingly common, and I can't seem to properly diagnose what is causing this problem.
This all started when I installed a new HDD, a WD Blue. Of note is that it spun at 5400rpm, which I initially deduced to be the source of my problem. I have since replaced the WD Blue with a WD Black that spins at 7200rpm, yet the problem persists.
This problem is very inconsistent. Normally, my computer's latency is fine when I boot it up in the morning. The longer it stays on, the worse the spikes get. Sometimes, restarting the system provides a temporary fix.
Here are things that I've already tried:
and in text: https://drive.google.com/file/d/1WvgF3pWvXAUwVcdG8Hng-2d1LLxepfPT/view?usp=sharing
Here's a summary of my desktop via Speccy: https://drive.google.com/file/d/1Hj3aQVuB_SC4k-8rT5waenGOmvh2HvNe/view?usp=sharing
I posted a thread like this a few weeks ago, but as I couldn't get any help I resorted to resetting my PC. That fixed the problem for a while, but it's back now. Hopefully I can get it fixed for good this time.
Let me know if you need any more information from me.
- Defragmenting my HDD with Defraggler.
- Installing and routinely using CCleaner.
- Lowering the number of startup programs.
- Updating all my drivers.
- Updating my BIOS (currently American Megatrends Inc. R01-A4, 5/19/2016).
- Installing exhaust fans in my tower. These definitely do their job when it comes to cooling the system.
- Disabling CPU throttling for all programs.
- Moving the system pagefile to my SSD boot drive, as opposed to my HDD data drive. I also tried disabling it entirely.
- Replacing my Realtek HD Audio driver with Microsoft's generic HD Audio driver. When this didn't work, I disabled the motherboard's onboard audio entirely, via the BIOS menu. To be thorough, I even uninstalled the Realtek HD Audio driver with Display Driver Uninstaller.
- Disabling ALL audio drivers. I technically have three: a speaker system connected to my motherboard's onboard audio (as mentioned above), my monitor's internal speaker, with a driver handled by my GPU (since it has an HDMI connection), and my wireless headphones that connect via a USB adapter.
- Disabling my network drivers (both my WiFi card and my Ethernet port).
- Resetting my PC via wiping my boot drive and reinstalling Windows.
