Question Audio problem, can’t find solution..
Aug 28, 2023
12
Hello, I have a strange audio problem..
I've been searching the whole internet for the solution but can’t find anything ..
Third party apps like “Discord, Teamspeak and etc” capture everything from my voice to everything else that I’m watching.. and not only that but even when my mic is muted, people in my call can still hear what I’m watching in “YouTube or other platforms that is similar to YouTube “ can someone help with it, I brought this pc a month ago, and I’m starting to get worry something is f* up ..
Well you could open up the Control Panel Sound app and check the Advanced settings. Normally the Allow Applications to take exclusive control of this device and Give exclusive mode applications priority boxes would be checkmarked. That might help. Otherwise you might have to temporarily disable the other inputs so that only your mic is enabled when you're on calls. You might also check the settings for those apps like Discord and Teamspeak etc. to see if there's a setting to specifically limit the app to only using your mic as a sound source rather than just anything that's creating a sound on your pc. Or you could stop watching other stuff while you're on calls.
The problem is that other people are hearing their voices in the call, I don’t know how but I have the feeling that my pc is picking the sound out of the somewhere that it’s shouldn’t pick the sound from there 😀
